Hey guys,
all my effects with echo are creating a hugh overload on the master
see this video : https://www.dropbox.com/scl/fi/jteunpscebjd76dt6clm4/2024-10-15-201113.mp4?rlkey=zd0165urqwfm1nxfljsw76mon&st=advcew6l&dl=0
other effects work perfect, any idea? THANK YOU
EDIT : ok, ive figured out that it has to do with echo out stems, when i use command : padfx "echo out" 80% 1bt
then the tracks echo out perfect!
But when i want just a part of the stem or multiple stems to echo out, i get the overload!
So this command gives me overload : padfx "echo out" 80% 1bt "stemfx:MeloRhythm"
& also command : padfx "echo out" 80% 1bt "stemfx:vocal"
EDIT2 : I use the STEMS+FX pad, is that one original from vdj, i mean, i don't think this was a add-on in downloaded
geposted Tue 15 Oct 24 @ 6:16 pm
edit : solved, very strange, but i have add 'blink:5000ms' at the end of the script! And blink doesn't work :)
geposted Wed 16 Oct 24 @ 5:34 am
