Hi !
Do anybody know how to customize the pad fonction.
For exemple i want to set up
1/ Stems
2 / Hot cue
3/ Sampler
3/ Loop roll
Do you have an idea ?
Thank for your help.
James
geposted Wed 16 Oct 24 @ 5:48 pm
Read the Pads Section of the User Manual.
geposted Wed 16 Oct 24 @ 5:53 pm
Thank you.
I found how to do it.
VDJ is such a good software.
Thank you for your help.
geposted Sun 20 Oct 24 @ 3:24 pm
