Hi everyone,
I have an issue with the autoheadphone setting only in ddj800. Selecting to switch the deck when loading a new song doesn't change to the new deck. On ddj1000 and ddjsb3 working perfectly. Any ideas about this???
Thank you in advance!
geposted Tue 22 Oct 24 @ 7:09 am
It works fine here.
What you need to know however, is that if you manually change PFL channel (by pressing the CUE/PFL buttons), then autoHeadphones will stop working, at least until setting the PFL channel back to what "auto" would have do.
So, make sure that you don't mess with PFL manually, or if you do, that you restore the PFL status on how "auto" would. This includes decks 3 & 4 as well.
PS: I would also recommend to switch autoHeadphones setting to "OnLoad" instead of "always"
geposted Tue 22 Oct 24 @ 8:58 am
Hello, thank you for your response. I tested the onload mode and encountered the same behavior. Are you indicating that when I manually press the cue button, the selected mode is deactivated and must be re-enabled? I was not aware of this.
geposted Wed 23 Oct 24 @ 4:08 pm
