Cant get the hang on why some auto set of cuepoints are visible and some invisible by auto in diffrent tracks.
1.
Why doesnt some tracks get auto cuepints (1-4) visible? I understand some remix/version hard to auto. But a classic like Snow-Informer (clean Extend) dont get any by auto. Strange! Possible to rescan and get points? (I have "get cues from tag"tags in auto)
2.
Is it possible to easy access to show and hide cuepoints without go to POI editor and choose individually on every point?
1.
2.
geposted Tue 22 Oct 24 @ 3:44 pm
Alwauysdo the cue points yourself, Also digital 1-2-1s will have a consistent bpm, recorded from vinyl, will not have a perfect tempo across track. If you get the start right, then line up the track at the end, and have all the bars landing on the grid, then your good, but if it isn't you have work to do, so you can sync later with no worries
geposted Wed 23 Oct 24 @ 5:01 am
