I'm really excite to use this function!
I'm "time coding" my music with OS2L to activate my scenes in QLC+ to sync the light to the music
I want to do a PAD page to mark hot cue "action" in the files but with "os2l_scenes" or "o2sl_button"
In my mind it would work like the hotcue pad page, normal push sets the action, shift+push removes the action. With this I cant tag much more quickly the music with the scenes that I want.
So, how can I do it? is there any VDJ Script that can do this?
And another thing, in a future update it would be nice to see more integration with this, like the ability so "Show or Hide" OS2L marks to no clutter the waveform and some visual indication on where the OS2L actions is set on the file, something like this:
Now for the possible bug,
While taging the music with OS2L actions I notice that when I put the mark les than 0.020 beats closer the the whole beat , the "OS2L tap" to send the BPM overrides the OS2L command OR maybe OS2L can just send 1 command at time, so when the "TAP" command is active no other command can be activate.
As such, I can't mark the music with the "SNAP" option turned on.
VDJ Version: 2024 b8350
geposted Wed 23 Oct 24 @ 1:22 am
verb is cue_action "STRING"
I made this, it does POIs for os2l scene calls or midi [yep midi out of vdj to other software], it also functions as a live input if you want to override the poi [again, os2l || midi]
popup skin window
4 banks of 64 buttons
all buttons are nameable
POIs placed have button name
goto navigation buttons
hardware mappable
mac or pc
I think there's about 10 people using this so far.
Earlier video demo, [has been refined since]
popup skin window
hardware mappable
mac or pc
Can't say much to the bug, I'm not sure what os2l tap is, I do know you can't have 2 action poi on the same frame.
geposted Wed 23 Oct 24 @ 2:01 am
Thank you so much! this verb doesn't have a description in the manual so it take me some minutes to figure it out how to do it but I got it to work!
Do you know If it is possible to change the "cue type" to marker only? I dont want to set any cue, I just want the text and position and sometimes I want then to be invisible.
This is so cool! the buttons changing dynamically as you type is something that amazes me! Virtual DJ is so powerful!
OS2L sends BPM information to DMX software by "taping", by definition: "tapping" in BPM refers to the manual method of determining a song's tempo in beats per minute (BPM). This is often done by tapping a button or key in rhythm with the song's beat. As you tap in sync with each beat, the BPM calculator will average out your taps to estimate the tempo of the track.
So if I use the OS2L cue action os2l_scene "scene7" with the quantize option ON or in the POI with the SNAP on, the bpm tap cancels the cue action.
geposted Sun 27 Oct 24 @ 8:46 pm
Hey Bruno. I discovered the OS2L "problem", too. As soon as the APOIs/OS2Ls are to close to each other... (in my case the beat signal mostly is the dominant.) I solved it by set sending OS2L to off in the options. With this there is no beat sending/tapping signal (but still your APOIs). But because I need the BPM in QLC+, too, I use the software "loopbe". Loopbe fetches the BPM and I can send this via MIDI to QLC+ (and other hardware). In QLC+ I made VDJ as Input in universe 1, opened a new universe (universe 2), where I have the loopbe midi input. With this I can have the speed and the OS2L, snapped to the VDJ grid.
geposted Wed 20 Nov 24 @ 4:36 am
Hello. I would be interested in getting a script for entering POIs directly from "LOCODOG"
How can I get in touch?
geposted Fri 07 Feb 25 @ 4:33 pm
I'll send you a PM soon.
geposted Fri 07 Feb 25 @ 5:01 pm
Ok.thank you..
geposted Sat 08 Feb 25 @ 8:51 am
