The last three tracks that I've run stems for, don't seem to be generating stems properly or vdj isn't recognizing them.
When I try to remove one or more the 5 different stems from the track, there is no change to the sound.
Another thing I've noticed is that on these three most recent tracks where I've tried to create stems, there is a difference in the bar that appears under a track compared to other tracks where stems have been successfully generated. The bar under these tracks is fainter.
I haven't changed anything in either vdj or on the laptop (Windows 10, 64-bit).
I tried deleting the stems, rebooting, and then creating the stems again, but still the same.
geposted Fri 25 Oct 24 @ 12:35 am
A pro user since 2008 and I get no response?
Kind of ridiculous...
It seems to mostly be a problem with longer tracks ~13 minutes.
geposted Thu 07 Nov 24 @ 2:04 am
that would be your maxstemlength setting
geposted Thu 07 Nov 24 @ 3:59 am
Even above maxStemLength the stems should still be calculated as needed, just not for the entire track at once
geposted Thu 07 Nov 24 @ 4:27 am
What are the tracks? Artist and title.
Also, what kind of tracks, from where? Are they full studio quality or compressed? From your hard drive or from a streaming service?
If you state what the tracks are, others can test with the same tracks.
geposted Thu 07 Nov 24 @ 12:25 pm
Thank you!
geposted Thu 07 Nov 24 @ 9:36 pm
solved now, thanks
geposted Thu 07 Nov 24 @ 9:37 pm
