Topic: Dual Delay help
Does VirtualDJ have a effect simalar to Traktors Dual delay effect?
geposted Sun 27 Oct 24 @ 7:10 pm
I need you guys help. I'm trying to find out because I think it's a pretty cool effect. I know my favorite dj software virtual dj can do it also.
post an audio or video sample of it and maybe someone can come up with something.
no clue what the one you say sounds like
you might try this add on https://virtualdj.com/plugins/?addonid=81216
i didn't make it but sounds like what you want
also there are many other delay plugins to try :-)
also you may need to active post fader fx in options
Thanks alot. I knew it was in there somewhere.
Seems like ever since I downloaded that plugin. Virtual dj cuts out my songs whenever I mix music. Has any one else experience this issue? Never done that until I download the plugin. Idk though.
It does it whenever I press the flanger effect is something going on with it?
Nevermind it done it all of a sudden. I stepped away from My laptop a minute and came back it was mute half the song when I was recording.
