Topic: AlphaTheta XDJ-AZ not connecting
I am getting a "Failed to connect" error when trying to use the XDJ-AZ with Virtual DJ. Any help and guidance would be appreciated.
geposted Thu 31 Oct 24 @ 12:24 am
It is not yet supported hardware.
Ah, thank you for the info and saving me from additional hours or days of frustration. I'm coming from a XDJ-XZ and am not a DJ so I had no idea that the hardware would need to be supported.
Would you happen to know when the XDJ-AZ will be supported?
I can't say for certain, some cases hardware offers new software based functions that need to be beta tested for all users, that can delay things.
VDJ's hardware team are professional grade hardware testers and they have found HW bugs that manufacturers didn't find, that can delay things waiting for a FW patch.
Like I said I can't say for certain, so don't go planning any weddings or running nuclear submarines with this information but from public availability of the hardware to software support USUALLY takes 4-6 weeks.
If you keep an eye on this, it will let you know when support goes early access
https://virtualdj.com/products/virtualdj/changelog.html
I see, thank you for the information and appreciate your response.
The official answer is:
Yes, it's in our immediate plans to support Alpha Theta XDJ-AZ controller.
We can't and we won't provide an ETA. It will be supported when it's ready.
I did not see this device on the Virtual Dj website as supported and that is why I asked the question before I buy. Thanks to all of you for your quick responses and hopefully within a year or less this device will be supported.
It's dec 15 2024 and still not supported. Considering learning serato and being done with it.
Serato only just added support a few days ago (Dec 10th).
From the Development Manager:
djdad wrote :
ETA is next month
Will there be beta testing like the Rane performer?
djdad wrote :
ETA is next month
ola alguma previsao dessa atualização, estou ja com minha xdj az e preciso trabalhar
Soon!
BUILD 8526 (18.02.2025) Early Access !!!!!!
-Support for Pioneer XDJ-AZ 🥳🥳🥳🥳🥳
I have already discovered one problem: the time in the AZ display is not changed when the pitch is changed and then differs from that in VDJ.
At first I had a brief problem switching to vinyl mode, but later it worked perfectly.
The transfer of the wave to the monitor is much more precise than with the RX3, thank you very much for that :-)
Hi guys, is this where you would put any feedback on the AZ early access mapping?
