Hi everyone!
I have a lot of songs with phrase changes. For example, instead of the next 1 there might be a break... and then the next phrase starts. With the beat anchors I can make sure that at least the 1 is set correctly in case the break is not a multiple of 4. But ideally I want the phrase markers to still align with the song.
.png)
So for this example, there's the pause and then I would like to have another fat blue line indicating the start of a new phrase on the one after the break.
Beat anchors only move the 1 but not the phrase. The POI adjust_cbg command adjusts the whole song so that it is off the next time I want to play it.
Is there any way I can realise this in Virtual DJ?
.png)
geposted Thu 31 Oct 24 @ 12:51 am
I do the above, and it's really only feasible with the plugin [it's actually 2 plugins, one does the anchors, the other does the marker]
If windows, and you think it worth a beer send me a pm an I can send you files and a padpage.
There is also the 1 of 4 checkbox in the bpm editor when adding a anchor but I'm a long time past using that so I don't really know if it's right for your needs.
geposted Thu 31 Oct 24 @ 1:05 am
