Hallo ich brauch dringend Hilfe. folgendes Problem. Mein Prime 4 hatte immer große farbige Wave formen. aber jetzt ist 1zu 1 Vdj auf dem Controller angezeigt wie kann ich das ändern?
geposted Thu 28 Nov 24 @ 3:37 pm
Hast du ein BIld?
geposted Thu 28 Nov 24 @ 8:23 pm
vielleicht hilft dir das weiter:
Prime 4 has a fully functional and customize-able 10" touch-screen offering all the information needed for your mix. The default GUI for the screen will be automatically downloaded the first time you connect the Prime to a computer running VirtualDJ (Internet connection is required at least for the 1st time)
The default GUI of Prime 4 offers 3 main views, with 2 Decks, 4 Decks Full and 4 Decks Swap (with 2 Full Decks and 2 Mini Decks), along with views for Large Browser and Settings.
Hold SHIFT down and then press the [VIEW] button on the Prime 4 to cycle through the 3 different Deck views.
Use the VIEW button to toggle between the selected Decks view and the Large Browser view (with Mini Decks)
geposted Fri 29 Nov 24 @ 10:28 pm
