I notice on his picture, the lowest row of pads is not lit up (only 7 rows, not 8).
geposted Wed 11 Dec 24 @ 10:46 am
I'll look for the problem!
Thanks for the answer.
geposted Wed 11 Dec 24 @ 1:57 pm
My update problem wont let me upload my songs from my documents
geposted Sat 14 Dec 24 @ 2:31 am
Hello
In the new version 2025 in the sampler the pads on Traktor f1 not working but working only the select bank and the stop button on the bottom button (inside the program is all ok).
I select other skins, all the same result.
Traktor F1 working ok with other programs.
https://drive.google.com/file/d/12KeGqBlIBk_RZKWOlMcXswIaRfs4DhQe/view?usp=sharing
geposted Thu 26 Dec 24 @ 6:35 pm
user8651297 wrote :
Hello
Ok the problem was solved by Greek forum
geposted Fri 27 Dec 24 @ 4:23 pm
The solution was to set both SamplerIndependentDeckBanks and SamplerSpanAcrossDecks to No (and restart VDJ).
geposted Fri 27 Dec 24 @ 6:10 pm
Greetings all
I am also having issues with my sampler
When i trigger some samples it records and begins playing a loop of whatever song is on the deck
My settings are as below
geposted Fri 27 Dec 24 @ 9:37 pm
Same here, the layout on the berigher pads doesn't respond to the same buttons as it did on the laptop. It's now a mess and I can't figure out why.
geposted Sun 29 Dec 24 @ 9:42 pm
