VDJ will go for a couple of months with no issues and then all of a sudden it will freeze/hangup. There is nothing in the windows error logs and I have updated my pc/VDJ and installed ParkControl.
Device name DESKTOP-B1CPTQ8
Processor 12th Gen Intel(R) Core(TM) i5-1235U 1.30 GHz
Installed RAM 8.00 GB (7.69 GB usable)
Device ID D30069C6-F4F5-4F3D-A88E-67CA2A7647C2
Product ID 00356-07445-26710-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch Touch support with 10 touch points
Any advice? Thanks!
Any advice? Thanks!
geposted Fri 06 Dec 24 @ 6:58 pm
Hi. Gotta be honest, 1.30 Ghz is too low for these kind of software, processors with the letter "U" are designed exclusively for office purpose laptops and 8Gb RAM isn't enough for today's standards, not just for VDJ but any software out of Windows Office environment. I'd recommend you to make an effort and buy a new laptop
geposted Sat 07 Dec 24 @ 10:18 am
If you don't use stems or HD video then VDJ will literally run on a toaster.
geposted Sat 07 Dec 24 @ 10:42 am
