my stems, button on the performer is not working, let rephrase that none of my stems button are working on the device or software....
i have dell laptop ntel(R) Core(TM) i3-8145U CPU @ 2.10GHz 2.30 GHz
before i did the update back october the stems was working, afterward i haven't been able to run any stems function, i have a dell desktop it works perfectly with any problems and i have install the latest version on both machine. any sugguestion
geposted Sat 07 Dec 24 @ 6:01 pm
Reset the pad page and see if that solves the issue. I had to do that as well, you can reset it in the Edit Page.
Info here: https://virtualdj.com/manuals/virtualdj/editors/padseditor.html
geposted Sat 07 Dec 24 @ 6:02 pm
check the setting stemsRealtimeSeparation, probably set to "Fully disabled" ?
But with Intel i3 8th gen and no discrete Video card, real-time Stems separation will be very slow, so perhaps you need to prepare Stems in advance for your most played Tracks and have the setting to "Prepared"
geposted Mon 09 Dec 24 @ 12:27 am
I appreciate The advice that was given Believe it or not I uninstall virtual and reinstall it and now my stems is working on my rain performer
geposted Wed 11 Dec 24 @ 1:54 pm
