Hi guys sometimes when I have my set Im struggling to come back to the full song once I played with Stems...
Meaning lets suppose I have just Vocal and Melody active and I want to jump back to the original song...instead of pushing the three buttons (bass, kick,hihat) simultaneously.
Is there the possibility to create a button and assign it to a pad which resets all the active STEMS?
geposted Sun 08 Dec 24 @ 4:03 pm
( stem_pad vocal ? : stem_pad vocal ) & ( stem_pad instru ? : stem_pad instru ) & ( stem_pad bass ? : stem_pad bass ) & ( stem_pad kick ? : stem_pad kick ) & ( stem_pad hihat ? : stem_pad hihat )
like that, probably put it on padshift 4
thanks to the team for brackets, without them that script would get real ugly.
It should be [but currently isn't] a param thinking about it
stem_pad resetAll
geposted Sun 08 Dec 24 @ 4:22 pm
Thanks will try that!
geposted Sun 08 Dec 24 @ 5:27 pm
stem_pad resetAll
stem_pad resetAll
It works perfectly! Thanks VDJ FAM!
geposted Tue 10 Dec 24 @ 9:25 am
hey guys...can you please add a piece of code to that script which reset not only the stems but also the stems effects? like vocal echo or instr echo? It could be helpfull to have a FULL RESET when pressed.
I know it's possible because there is an option already available to tell VDJ to fully reset when a new track has been loaded.
Thanks in advance!!!!
geposted Sat 21 Dec 24 @ 8:03 am
Time to start reading
https://virtualdj.com/forums/223743/General_Discussion/Script_School.html?page=1.15
geposted Sat 21 Dec 24 @ 10:33 am
LOL
Hopefully you will add the line of code I am requesting...because I am totally lost, ,its not about reading it's about being able to read understand and implement...
I know I am asking a favor.....but my mom taught me "asking is legit, replying is a courtesy"...
Thank you for your amazing work!
Cheers,
F.
geposted Sat 21 Dec 24 @ 3:29 pm
Your first question was complicated, your second is not, how to link commands together is covered in the lesson, how to disable all effects is briefly mentioned too.
geposted Sat 21 Dec 24 @ 5:13 pm
Ok noted thanks anyway...
geposted Sat 21 Dec 24 @ 5:15 pm
Hey Locodog what's up?
I have read and tried, but unfortunately with no success.
What I am actually looking for is disabling the following effects if either one of them is active
padfx "echo out" 80% 0.5bt "stemfx:MeloRhythm"
padfx "echo out" 80% 0.5bt "stemfx:vocal"
Please note that normally to disable one of the above, I just need to press once again the assigned pad button.
I have both configured on a pad and sometimes I forgot I pressed one of those, so if the STEM reset button would also disable the above effects, it would be perfect.
Let me know if you can help me out.
Thanks in advance.
F.
geposted Fri 03 Jan 25 @ 4:41 pm
