Topic: Notebook with double screen
Hello everyone,
I recently purchased a new notebook (asus rog zephyrus duo) which has a small touch screen in addition to the traditional screen.
All applications work correctly extending across the two screens or splitting onto both except vdj. (discovered that the cause is edge blocking)
Has anyone in the same situation asked for/made/found/modified a skin useful for the cause?
Thank you
geposted Mon 09 Dec 24 @ 4:01 pm
What would you have on the touch screen?
To make an example: if i open a chrome page in the main screen there is the possibility to extend the chrome page also in the second screen or to split the page in both screens.
This would be great in order to use the sampler o many other functions in the touch screen panel.
I've tried to split vdj in both screens using the windows settings, but this is not possibile in full screen mode, so in the mini touch panel it comes very very little.
you probably want a floating window to drag onto the 2nd screen.
Probably that would be the best solution.
Any idea if possibile ?
Yeah I make these things for people pretty regularly for a few beers.
all the info is here if you want to make yourself
https://virtualdj.com/wiki/Skin%20SDK
if this sort of html work isn't your thing, pm me some drawings of layouts you want and your 2nd screen resolution.
I had one of them for a short time but had to return it due to horrendous latency that couldn't be fixed.
I found the best solution was to use the main screen for VDJ on a normal skin then use the second one as a video monitor on the left, notepad in the middle and lighting software on the right.
