Quick question.....i dj for a company and we of course use virtualdj software and we use a denon controller with the software....and i have just purchased a pioneer controller to also dj with...the question is can we use both controllers not at the same time but at different events from the same computer on different days.
so basically one computer but different controllers on different events!
geposted Mon 09 Dec 24 @ 6:56 pm
The answer is technically yes (I assume you've checked that the hardware you plan to use is officially supported on the hardware support page, otherwise you'll have to map it yourself if possible)
but you need a pro licence.
More info here: https://virtualdj.com/products/virtualdj/price.html
geposted Mon 09 Dec 24 @ 7:09 pm
Yes, just keep a sound profile in the audio settings page for each controller and you can swap between them with just one click.
geposted Mon 09 Dec 24 @ 7:10 pm
Thank you that helps a lot
geposted Mon 09 Dec 24 @ 7:17 pm
