A keyboard mapping that worked for years stopped working a week or two ago.
The key still works overall and I tried the mapping on another key with no impact.
Mapping is:
doubleclick ? setting 'eqmode' +1
Removed the doubleclick condition. Tried -1. used " as opposed to '.
All with no luck.
Any ideas?
W11 B8350
Mapping is:
All with no luck.
Any ideas?
W11 B8350
geposted Mon 09 Dec 24 @ 9:41 pm
try with just
eq_mode +1
setting might be string based.
eq_mode +1
geposted Mon 09 Dec 24 @ 9:46 pm
That kind of worked...
It goes between frequency and whatever stem mode you have selected, as opposed to going through all the options as before.
geposted Mon 09 Dec 24 @ 9:51 pm
if you want all modes, query setting by string and select the next setting
setting eqmode frequency ? setting eqmode EZRemix : setting eqmode EZRemix ? setting eqmode ModernEQ : setting eqmode ModernEQ ? setting eqmode Stems : setting eqmode Stems ? setting eqmode frequency :
geposted Mon 09 Dec 24 @ 10:03 pm
I will check it out. Knew you would bring a good answer.
Any idea what broke the mapping to begin with?
geposted Mon 09 Dec 24 @ 10:04 pm
