Hi, I just got the Pioneer SX3, and the sound isn't working correctly. I have clicks and pops while the music is playing. I already turn off the ultra latency, also I changed the latency configuration from 0 to 64, 128, 256, 512, even 1028. Th SX3 driver comes with his own ASIO latency adjustments, I also tried to change the configuration, but I keep getting the issues with the sound.
Can someone help me with this issue?
Thank you!
Thank you!
geposted Fri 20 Dec 24 @ 2:17 pm
Run some latency checking software on your computer, without the SX3 connected, or any other software running, and see what results you get.
https://www.resplendence.com/latencymon
geposted Fri 20 Dec 24 @ 2:21 pm
Can you also try with the setting ExclusiveAudioAccess to Yes ?
geposted Fri 20 Dec 24 @ 2:34 pm
Thank you for your response
geposted Fri 20 Dec 24 @ 4:16 pm
Thank you, I already have the audio exclusive access on Yes
geposted Fri 20 Dec 24 @ 4:17 pm
Also install the windows ultimate power plan if it's not there and activate it.
geposted Fri 20 Dec 24 @ 4:22 pm
Thanks, I'll verify if I have it
geposted Fri 20 Dec 24 @ 6:42 pm
