Hi,
Looking for a script to undo (that is reload) the last deck that was ejected (unloaded). Any help would be appreciated. Thanks
geposted Sat 21 Dec 24 @ 10:23 pm
undo_load
geposted Sat 21 Dec 24 @ 10:40 pm
Thanks Locodog, but this function only works on deck 1, not deck 2.
geposted Sun 22 Dec 24 @ 1:36 am
If you read the vdjscript documentation for undo_load, you'd realize the right way to use it it for your needs
Maybe try using undo_load any?
geposted Sun 22 Dec 24 @ 1:57 am
expected, you're on a keyboard mapping, it will default to the selected deck,
specify a deck or tab over to select the deck you want.
geposted Sun 22 Dec 24 @ 2:07 am
VINYLTOUCH....your mapping suggestion worked. Thank you.
geposted Sun 22 Dec 24 @ 3:57 am
