Hello. I use the DDJ RR controller, and it has one very strange bug. Sometimes, when I press the hot cue button, the pfl itself switches from one channel to another. Let's say if I loaded a new track on the left deck and I have the left track listening, then when I press hot cue 1, the listening switches to the right deck. This happens on both the left and right channels, but not on both at the same time. What's even stranger is that if you press the hot cue lightly (but still enough for it to work), the pfl does not switch to another channel, but if you press it a little harder, it switches. And the error is 100% software-related, because after rebooting the program, it disappears. Also, a few years ago I had another copy of the DDJ RR, which had the same problem. It does not happen often, once every two or three evenings. I recorded a video showing how this happens. Don't pay attention to the sound in the video, it came from another source and doesn't match what's happening in Virtual Dj. And another thing - it looks like this glitch only works when you press hot cue 1. This doesn't happen on hot cues 2 and 3, and i'm not shute about another 4-8, forgot to check
https://streamable.com/ujw7v7
geposted Sun 22 Dec 24 @ 5:42 pm
Try switching pflOnSelect and maybe autoHeadphones off in your options and see if that helps.
geposted Sun 22 Dec 24 @ 6:37 pm
Thanks for that tip, i will try it
geposted Sun 22 Dec 24 @ 9:21 pm
