Whenever I change an aspect of the skin (This is a default VDJ skin so nothing custom) It causes the the UI to freeze completely, I can still use VDJ via the console and plays music perfectly fine. But once I try shutting down the software it causes the whole laptop to crash and messes up windows. And even when I use the essential pack it eventually freezes again but instead of crashing the whole operating system it shuts down itself and then pops up with the message failed to initialise directX. I've redownloaded windows 11 (keeping the files). I've tried to check all the drivers individually for updates and clean installed VDJ, I even updated the firmware on my console (Mixon 8 pro).
Apparently, Dell laptops aren't recommended for VDJ as interferes with some background processes even though it was working perfectly fine before the VDJ 2025 update.
My specs:
G16 7630
RTX 4060
i7-13650
32GB ram
Does anyone have any previous Experience with this problem
My specs:
G16 7630
RTX 4060
i7-13650
32GB ram
geposted Sun 22 Dec 24 @ 6:31 pm
