(I hate filing bug reports when I have a case that can't be reproduced, but i've seen this happen at least a dozen times so will try and add details if they come up).
Every now and then, the linked tracks panel will freeze and the content won't update. I can select and scroll through songs in the panel and drag them to decks, but not create new links. The linked tracks won't update when the source of the linked track changes. Closing the panel and reopening doesn't fix it. Changing the panel settings (alternative, similar, recommended, linked) or source (active deck, browser) doesn't change anything- the content stays the same and doesn't update. The only fix i've found is to restart vdj. It only seems to happen after some time, maybe 20+ minutes.
Has anyone else seen this? Thanks!
Windows 10, v2025 b8472
geposted Mon 23 Dec 24 @ 4:26 am
Yes. I'm having the same issue and it's frequent enough to be real annoying now.
geposted Tue 23 Dec 25 @ 7:13 am
