Moin, wo kann ich die letzte 2024 Version downloaden. Seit der 2025 Version funktionieren meine ganzen Samplerbanks auf dem Traktor F1 nicht mehr.
geposted Mon 23 Dec 24 @ 9:53 am
geposted Mon 23 Dec 24 @ 9:57 am
Super - danke. Angenehme Feiertage. LG
geposted Mon 23 Dec 24 @ 10:00 am
nur zur Info die neuste Version "install_virtualdj_2025_b8490_pc" scheint das Problem gelöst zu haben.
geposted Mon 23 Dec 24 @ 10:04 am
so... brauchen nicht weiter zu suchen. Ist echt aus dem Portfolio entfernt worden. Habe den Support kontaktiert..
Man kann aber immer noch per Drag&Drop aus dem Explorer die Titel einladen.
Hier die Antworten vom George vom support:
Short answer > its 2024, Laptops come without Optical drives, so we had to hide the CD icon to simplify things. However if your drive appears in windows File explorer, you can still drag and drop cd tracks to the VirtualDJ decks., That still works
i think there was no way to make VirtualDJ detect if there is a cd drive or not. It had to either show or not show. And since todays computers have no optical drives, developers decided to hide it. At least what i remember when i talked to a developer, some time ago.
Here is another workaround, Make a List / virtual folder. And drag and drop cdtrack files to it from a cd. And keep it
I believe that all cd-audio disks have the same contents, like cdatrack1, cdatrack2 etc
So you will have a tamplate that should work with any cd you insert.
geposted Mon 23 Dec 24 @ 4:00 pm
