Hello! Track cleaner is duplicating POIs and creating an additional beat grid marker. I have a video to demonstrate: https://youtu.be/DmF0Sd36O2g
-Examine track that has already been analyzed and had manual beat marker and tempo adjustment. Observe existing POIs.
-Create track cleaner edit.
-Open new edit and observe duplicate POIs and additional shifted beat grid. All other POIs are in the same spot as their original counterpart, but the new beat marker is in a different position.
-Where does this different position come from? Reanalyze the original track and observe that the original beat marker is in the same spot the new track edit beat marker is created (but the track edit beat marker retains the manually added tempo instead of the original).
In summary: When creating edits with track cleaner, POIs are duplicated and an additional beat marker is reset to the original position.
v2025 b8490
Thanks!
v2025 b8490
Thanks!
geposted Tue 24 Dec 24 @ 4:45 am
