After editing a skins then Compress it to a zip file VDj Will Not Open or locate it,But the unzip will open. On my Mac book Pro
geposted Tue 24 Dec 24 @ 11:53 pm
likely you zipped the parent folder, not the files.
Open the zip; if you see files it's right.
if you see a folder [which contains the files] then you zipped 1 level too high.
A common mistake I do a few times a year.
geposted Wed 25 Dec 24 @ 1:21 am
I Just un-zip it change the name then zip it back with new name & still will not open.
geposted Wed 25 Dec 24 @ 4:16 am
ok ThankYou
geposted Thu 26 Dec 24 @ 11:22 pm
