Used to. In file operations.
geposted Sun 29 Dec 24 @ 3:35 am
You still can. The Filename can be changed from Right-click->File Operations ->Rename, (you get a popup window) or in Tag Editor.
Works fine here.
Can you post screenshot showing what you get or not getting as result ?
Works fine here.
geposted Sun 29 Dec 24 @ 3:03 pm
I'll try again. >Right click on file operations. drop down to rename . add info. click the window. mouse over the file (which is not loaded on either deck) but now I get no change? Been doing it since 2013. I'm lost.
geposted Thu 02 Jan 25 @ 1:05 am
OK. I used the TAG editor, & that got the results I needed.
geposted Thu 02 Jan 25 @ 1:07 am
Ok, I just did the new update & it erased all of the talk-up intros I needed for my radio show! What's the point of updates?
geposted Thu 02 Jan 25 @ 8:40 pm
