hi guys, can you help me with the settings for this configuration:: djm700/cdj1000mk3/Pioneer DJ Interface 2 ?
geposted Mon 30 Dec 24 @ 10:10 am
- The CDJ-1000 MK3 is not a MIDI/HID device so it will not be able to control VirtualDJ functionality directly.
You'll have to use it to play Timecode CDs and use it with VirtualDJ's DVS system. - The DJM-700 doesn't have a soundcard nor does it seem to send MIDI input/output for all controls, so there is no way for VirtualDJ to except sound input/push sound output to it's master output directly, nor can VirtualDJ react to control changes.
You'll need an external audio soundcard to route the DVS signal into VirtualDJ for processing and to allow VirtualDJ to send the audio output for each channel back into the mixer for mixing/output to it's master.
There are many choices for this.
You already said you have the Pioneer DJ Interface 2 which doesn't seem to be natively configured but probably could be done in the Audio Config tab.
Another good option that is at least current/still available in stores and is natively configured - the Denon DS1
geposted Mon 30 Dec 24 @ 1:31 pm
