I learned (late) that you can designate a folder for stems only. I now have many folders with a mix of stems and full tracks. Is there a simple way to move those stems into the folder I have set aside just for stems?
Thanks.
Thanks.
geposted Mon 30 Dec 24 @ 8:47 pm
Not easily but you need to change the setting to dedicate a specific stems folder.
All you then need to do is create one stems file from each folder your music is in, which will then create a special coded folder in your new location and then you can move all the other .vdjstems files from the existing folder over and they will be recognised. Hopefully you don't have too many folders :)
The new folders will look like this:
geposted Mon 30 Dec 24 @ 10:26 pm
Thanks
geposted Mon 30 Dec 24 @ 11:05 pm
Maybe the stems can stay where they are if I can copy the actual songs to thumb drives when needed *without* copying the stems too. Is that possible? That would be copying to a thumb drive based on a filter, but not also copying the stems.
geposted Mon 30 Dec 24 @ 11:12 pm
