Any idea what might be causing this issue? Sometimes on a couple of my decks, if the fader is slightly below maximum on my DDJ-SX3 and I just push the fader up to full volume once, the fader in Virtual DJ glitches out and either drops volume way down, or it fluctuates up and down jerkily.
This only started happening recently, might it be a bug in the recent versions of Virtual DJ, or is it more likely to be a hardware issue?
Here's a couple short videos showing what happens. In each of them, I just pushed the fader to max and then didn't touch it again.
https://gyazo.com/6f3bd03a142708f955f265f73ce36c56
https://gyazo.com/1679b12c684831f1d4d7c2f09c4fcce4
geposted Sat 11 Jan 25 @ 8:35 pm
Knackered fader, either dirt on the contacts or a dry joint on the pcb, try compressed air, eventually the carbon tracks in a fader wear out [unless it's a optical/mag fader]
geposted Sat 11 Jan 25 @ 8:49 pm
Thanks, I'll give that a try. :)
geposted Sat 11 Jan 25 @ 9:11 pm
Same problem with a ddj sx2 last night. My right fader started sliding up and down as soon as I got close to the maximum.
geposted Sun 12 Jan 25 @ 3:15 pm
