hi,
vdj used to work perfectly until b8502 version. now it freezes. sometime it defrosts by itself but sometimes it crashes. never had this problem before.
it can't be a problem with my computer (i5, rtx 4060, 16gb from 2024)
should i install 8490 version ? thanks for help.
geposted Tue 21 Jan 25 @ 10:08 pm
ok...i think i founded the problem. it should come from the new option 'reset gain on load" . i think there is a problem with it. possible for you to check it ?
geposted Tue 21 Jan 25 @ 10:18 pm
