Is there a limited number of song that can be added to the "Add to Search Database"?
I've been adding songs to my music folder in Miscrosoft Windows 11 but when I try to add them to the Search, they don't show.
geposted Mon 03 Feb 25 @ 11:55 pm
No, there's no practical limit.
Also, how do you check if the files are on search database or not ?
By searching ?
Perhaps your search criteria are set incorectly ?
PS:
By typing "*" (asterisk) in search, you can see ALL the files contained in search database.
By searching ?
PS:
geposted Tue 04 Feb 25 @ 12:12 am
