Hello, I can't seem to figure out how to map a pad to disable/enable cue quantizing. I'm trying to change the setting like so: setting "quantizeSetCue" "Yes", but as far as I can tell this simply does nothing. I can manually go into settings and set quantizeSetCue to Yes and it works fine, but changing it through a script doesn't work. Any help would be appreciated, thanks.
geposted Tue 04 Feb 25 @ 3:34 am
The vdjscript verb is quantize_setcue. Also check @locodog's answer below for the alternative that is closer to your answer.
geposted Tue 04 Feb 25 @ 3:39 am
setting quantizeSetCue on
geposted Tue 04 Feb 25 @ 3:40 am
