I have this DJ2GO2 TOUCH controller.
I connect it to the computer and the computer recognizes it and everything seems fine.
The virtualDJ software also recognizes it and seems fine - but when I put a song on I don't hear it on the controller, I checked all the settings are correct in virtualDJ.
What am I missing?
If I put a song on with media software like VLC I hear it through the controller.
Only through VIRTUALDJ it doesn't transmit media.
Many thanks to everyone who tries to help me
What am I missing?
geposted Wed 19 Feb 25 @ 5:38 am
danielami wrote :
If I put a song on with media software like VLC I hear it through the controller...
This says windows has the hardware as the default sound device, disable it in windows.
geposted Wed 19 Feb 25 @ 5:44 am
But my hardware is on default in the settings.
geposted Wed 19 Feb 25 @ 5:56 am
So the the Audio Setting configuration is the same as the one shown in the user manual ?
https://virtualdj.com/manuals/hardware/numark/dj2go2touch/setup.html
geposted Wed 19 Feb 25 @ 7:29 pm
yes
geposted Mon 24 Feb 25 @ 7:28 am
Turn off Exclussive Audio Access for the DJ2GO2 soundcard in Windows sound settings
Or, as others recommended already, set your laptop soundcard as the system default playback device. This will prevent the OS from "locking" DJ2GO2 to a specific app.
geposted Mon 24 Feb 25 @ 7:35 am
First of all, thank you all for the answers, I really appreciate it!
But I also tried this:
The device is set to default
And I also disabled "Allow applications to take exclusive control of this device"
There is still a problem
geposted Mon 24 Feb 25 @ 11:15 am
See locodog's answer from 5 days ago...
geposted Mon 24 Feb 25 @ 1:28 pm
I tried it, it didn't solve the problem.
geposted Mon 24 Feb 25 @ 2:13 pm
So you set Windows audio to use your motherboard interface (e.g. Realtek) not DJ2GO, and you set VDJ to 'speaker + headphone' with master set to DJ2GO WASAPI chan 1 & 2 and headphones to DJ2GO WASAPI chan 3 & 4 (and your speakers and headphones are connected to the DJ2GO)?
geposted Mon 24 Feb 25 @ 3:03 pm
Of course, I defined it that way.
geposted Mon 24 Feb 25 @ 8:30 pm
There is news - I checked version 2018 (32BIT) and I can hear on the controller but the controller does not control the DJ software.
In new versions it is the other way around, the controller controls the software and the buttons work but the controller does not output audio.
All settings are the same.
geposted Tue 25 Feb 25 @ 8:07 am
This hardware did not exist until 2020, this is not difficult it is just a windows sound setting.
geposted Tue 25 Feb 25 @ 8:18 am
i had the same problem with VDJ2026.
my problem turned out to be a problem with a windows update which occurred recently.
Go to Device Manager and scroll down to Sound, Video and Game Controllers and click the drop-down chevron.
A list of devices will appear.
Find Intel Smart Sound Tehnology for USB Audio.
Disable it.
Also helps to disable NVIDIA Broadcast, NVIDIA High Definition Audio, NVidia Virtual Audio Devie (wave extensible)(WDM)
close their windows after confirming those devices are disabled.
restart pc
load up VDJ2026
you should now be able to click on 'NUMARK DJ2GO2 Touch' on the hardware tab in the selection screen in VDJ2026.
you should beable to gain full funtionality with the controller and be able to perform!
this worked for me. here's hoping it works for you!
Disable it.
restart pc
load up VDJ2026
geposted Mon 22 Dec 25 @ 8:56 am
