In smart link window it also shows tracks that are played after selected songs.
Inwant to delete songs from list because they add songs when im just searching and listen at home.
So manually I want to delete songs so only tje songs I ålay when DJing are showing.
Is it possible?
There are possible to mark and delete songs but when I load it again it still are there
Is it possible?
geposted Thu 20 Feb 25 @ 9:20 am
You should remove your history files from when testing at home.
The "database" for suggestions rebuilds every time.
So, after deleting the history files that you was just fooling around, the "new" suggestions database should come with much better results.
geposted Sat 22 Feb 25 @ 12:42 pm
