Hi Everyone - I am using a Numark NS6II controller and I was curious if the "Preferred Buffer Size" setting inside of the Numark driver is supposed to match the "latency" setting inside of Virtual DJ?
Right now, the driver is set to 512, and latency in VDJ is set to 128 and I've been having issues with audio distortion.
Thank You!
Thank You!
geposted Sun 23 Feb 25 @ 3:43 am
If you are using a native ASIO driver for the hardware, it's settings will be used, and the ones in VDJ will br ignored
geposted Sun 23 Feb 25 @ 5:15 am
Makes sense thank you very much
geposted Sun 23 Feb 25 @ 6:07 am
