I am pretty new to VDJ so this might be a user error, but I seem to have the loopmasters samples stuck in the sample pad. I can't figure out how to clear it so I can either load on the fly samples or anything else.
Am I missing something?
geposted Fri 28 Feb 25 @ 12:28 am
OK, stop looking!
To change the samples in the pads, right click on the folders in the sampler browser and click "set active". Hardly intuitive :P
geposted Fri 28 Feb 25 @ 1:35 am
geposted Fri 28 Feb 25 @ 1:56 am
locoDog wrote :
Thanks for that
geposted Fri 28 Feb 25 @ 8:03 am
If you are in default mode instead of 4 button mode, you can simply click these
They will often also be present as pads parameter buttons on your controller
geposted Fri 28 Feb 25 @ 10:21 am
