Hello.I already wrote that I encountered a problem when loading a new track and then pressing a hot cue there is a second-long sound glitch, something like a short "bzzzzzz". This happens quite rarely, maybe once per evening. But I noticed one thing - in the systemreport-session file there are entries like " Audio High Cpu Log [time] asio://F32...... (DDR-RR ASIO) : Peak cpu: 208.75% (1).
If there were no problems with the sound during the evening, then there is no mention about High Audio Cpu at all or value of the Peak Cpu indicator does not exceed 200-400%. But if Peak Cpu is more than 1000%, at this moment the sound is jammed. The time of these events coincides exactly, I specifically paid attention to it.
Maybe this will help to understand the cause of the problem? I tried all the settings in the performance section and I don’t know what else to do. The problem occurred on three different laptops (asus intel i5 gen 11 16gb ram, asus intel coreultra i7 gen 2 258 32 gb ram and lenovo intel core ultra i7 gen 2 258 32gb ram.
geposted Sat 01 Mar 25 @ 4:29 am
So, no one can explain what does audio hi cpu log mean and how to fix too high peak cpu?
geposted Mon 03 Mar 25 @ 4:13 pm
Raise a support ticket and send them the logs.
geposted Mon 03 Mar 25 @ 4:16 pm
