I am trying to set up a custom button that will stop Acapella if it is selected and stop any samples playing. I am close...
action_deck 1 ? sampler_stop all & stem_pad Acapella : action_deck 2 ? sampler_stop all & stem_pad Acapella
This almost works, the sampler stops, but it toggles Acapella - where am I going wrong?
geposted Wed 05 Mar 25 @ 11:00 am
action_deck 1 ? sampler_stop all & stem_pad Acapella ? stem_pad acapella : nothing : action_deck 2 ? sampler_stop all & stem_pad Acapella ? stem_pad acapella : nothing
query the stem pad, if on call it to toggle, if off do nothing.
geposted Wed 05 Mar 25 @ 11:44 am
Awesome, thanks
It suddenly twigged that they are based on ternary operators, it would be helpful to make that distinction near the start. But generally the VDJscript documents are pretty hard to wade through.
I notice in the list of verbs against
Perhaps plain English would make them easier to understand
stem_padit says
mute a stem (or isolate if pressed with Shift)..
mute a stem (or activate if pressed with Shift).
geposted Wed 05 Mar 25 @ 11:18 pm
user30376688 wrote :
...are based on ternary operators, it would be helpful to make that distinction near the start. But generally the VDJscript documents are pretty hard to wade through.
That you know what ternary operators are makes me think you'll be alright,
script is a language so you've got to practice to actually get it at an intuitive level and languages are never 100% consistent, really verbs are just function calls, some with default parms and many overloads.
If you want the verbose guide, skim thru my topics in this thread scriptSchool
A bit entry level but a skim thru will give you some insight.
geposted Thu 06 Mar 25 @ 12:17 am
