Topic: new skin help
HOLA
DjMiamisalsa wrote :
HOLA
for the new skin Vanced Gt .al buscar canciones en la barra ,se modifica o varia el skin ayuden a deshabilitar esa accion .Gracias
Aquilino les dejo un video
ENGLISH .Hi guys I need help with the skin 2025 VANCED GT , when I look for a song the king suffer modification ,please check the video below ,I would love to save this issue
Thank you in advance
geposted Wed 05 Mar 25 @ 3:54 pm
HOLA
HOLA
Disable the “Browser Zoom (Auto)” option in the main drop-down menu.
And also you should not leave something enabled if you don't know how it works.
thank you ,can u send me an screan foto how to do it .and this happen just with the new ADVANTED GT SKIN .ALL OTHERS SKING WORKS GOOD
Vanced GT is working fine too, you activated the automatic browser option, and that's what it does.
That you activate things and leave them like that even when you don't know what they do is not my fault, it's not the skin's fault.
I think I should make the main menu button even bigger so you can find it?
yes bigger Iyu a right
thank you
