Hi, I would like to map the pitch_lock feature using shift + pitch botton (slider), could you tell me how could I do if I want that it works just while I'm pressing shift and moving the pitch slider??
Thanks in advance!
Thanks in advance!
geposted Thu 06 Mar 25 @ 7:17 pm
SHIFT_PITCH pitch_lock on & pitch & pitch_lock off
geposted Thu 06 Mar 25 @ 7:35 pm
thanks so much!
geposted Fri 07 Mar 25 @ 8:44 pm
