I'm trying to figure out how show shaders in the video output with my camera ON TOP... so far the camera will not show on top of shaders unless I lower the opacity of shaders, which I don't want to do because there are music videos underneath that I'm trying to hide.
Is it possible to get this result while playing music videos?
Note: I am a VJ and my entire library are videos only. Any advice that requires me to enable shaders as the source for audio only files does not apply to my situation.
Thanks!
Thanks!
geposted Sat 08 Mar 25 @ 7:46 am
Shader on deck, cam output over master.
geposted Sat 08 Mar 25 @ 8:36 am
How do you mean, shader on deck? If im playing videos I have to enable shader in master and also cam in master, no?
geposted Sun 09 Mar 25 @ 12:54 am
