Hi!
I've set the following automix settings:
- automixMode "no mix"
- fadeLength -3.0
I believe there should be a 3-second silence between each automixed track, but there no silence at all. Is this a bug? I've read old forum posts that seems to indicate that this feature used to work, a few years ago.
Swing dancing DJs need this feature, so that the dancers have some time to thank their last partner, and perhaps find a new one.
Thank you!
- fadeLength -3.0
Thank you!
geposted Wed 12 Mar 25 @ 4:41 am
try fade remove nothing
geposted Wed 12 Mar 25 @ 4:51 am
