The manual says: "The lyrics will be represented on the timeline in purple and each line will be defined by a pink marker. Grab the pink marker and drag it to the desired position to adjust the timing. All lyrics located to the left of the marker will maintain their position while all lyrics to the right will follow the marker in order to preserve their timing."
This is OK, but sometimes it's just needed to adjust one phrase while the remain lyrics at the right are good, is there a way to override this behavior, maybe holding shit while dragging or something?
geposted Fri 14 Mar 25 @ 10:44 pm
