Hi I did a gig last night and my gain kept automatically going up to about + 13db I restarted the software but it kept doing it I also turned off auto gain and remember and it still kept adjusting the gain does anyone have an idea what was wrong I've used virtual DJ for over 20 years and this has never happened before I am on a 2019 macbook pro 32gb memory i9 processer going into mixtour pro controller
geposted Sun 16 Mar 25 @ 9:22 am
Anyone having same issues
geposted Sun 16 Mar 25 @ 7:23 pm
Did this happen on one or both decks (channels) ?
Perhaps your controller's gain slider is going faulty ?
geposted Sun 16 Mar 25 @ 11:10 pm
I also had a problem with the volume in the 8528 version during my work on Saturday... and also the controller (ddj 1000) did not respond correctly.... fortunately I also had the Nexus2 console connected and I was able to turn VDJ off and on again... after that everything seemed ok but when I returned home I went back to the 8502 version to see if it could also happen in that one (which I have been using since its release without problems)
I use MacbookPro M1 Max 16 cpu32
geposted Mon 17 Mar 25 @ 12:15 pm
