I have a ddj-flx10 and a ddj-800 and the laptop with the flx10 lags and stuttters while playing tracks we upgrded the laptop to a core i5, 16gb of ram and nothings changed.
on the laptop with the ddj800 when we touch the jog wheels it makes a squeal noise and we don't know how to fix that either
why do they do this and is there anyway to fix it? weve tried reinstalling, resetting laptops, changing laptops, changing mixers and dj decks but they still do ot, how do we fix it?
geposted Tue 18 Mar 25 @ 2:35 pm
Providing some technical specs from your laptop(s) would be a nice place to start..
geposted Tue 18 Mar 25 @ 3:26 pm
A good place to start is to make sure you re not using a unofficial/pirated version of VirtualDJ.
Download and install from here .. https://virtualdj.com/download/
If you like the software and need to use controllers, you will need a Pro license .. https://virtualdj.com/buy/
If you still have issues, then it's always a good practice to optimize your computer for best performance.
https://virtualdj.com/wiki/Sound%20Issues.html
geposted Tue 18 Mar 25 @ 3:35 pm
