Have I understood correctly that a change of hotcues and loops in CDJ, should be imported back in VDJ?
The option "import changes made in CDJ" has a checkmark.
Or do I need to launch the "sync" somehow?
I thought the change made on a CDJ would propagate to the original file used to create the CDJ export. But maybe the link between the files is lost when there is a CDJ export.
Because, when I drag a file from a USB stick which was made with export, the changes are imported in VDJ deck.
geposted Wed 26 Mar 25 @ 6:00 pm
