Hello, i bought the Controller and he works 90% perfectly with VDJ. There is a little problem with the FX Section of the Controller. There are 3 FX Select buttons, but only the first button works.
it must be a Mapping problem, because if i use Serato (but i dont like it ) all buttons are avaible.
I try many houres to edit the mapping in VDJ, but i loose. Is it possible, that you help me to resolve this problem?
geposted Wed 26 Mar 25 @ 7:12 pm
you have vdj in single fx mode.
@devs isn't it time this was changed from effect_3slots_layout to effect_single_slot_layout as that's the odd one out
geposted Wed 26 Mar 25 @ 8:55 pm
Sorry, what I have to do with this information? Shall I type in this code?
But where?
But where?
geposted Thu 27 Mar 25 @ 3:49 am
O.k., I have it! I must only change the view of the FX Slots, now all 3 Buttons are working!
geposted Thu 27 Mar 25 @ 4:45 am
