Hello, after playing for 2-3 minutes, the program freezes for about 10 seconds. There's no error message or anything similar. I can use the mouse or control the deck, but nothing happens during those 10 seconds. After that, it continues to run normally until it happens again a few minutes later.
My laptop has the following specifications:
NVIDIA GeForce RTX 4050 Laptop GPU
Processor: 13th Gen Intel(R) Core(TM) i5-13500H 2.60 GHz
Installed RAM: 16.0 GB (15.6 GB usable)
System type: 64-bit operating system, x64-based processor
I have the Numark Party Mix Live controller
geposted Fri 28 Mar 25 @ 4:54 pm
Make sure you are on a performance power plan and have the setting in power & battery to high performance.
These issues are usually related to CPU throttling as many newer laptops are configured for energy saving.
geposted Fri 28 Mar 25 @ 5:28 pm
