Hi, can you help me figure out what happened to me yesterday during a session? The sound cut out. I was DJing with Virtual DJ and a Denon Prime Go.
After 2.5 hours, the sound cut out. Could you tell me if this has happened to anyone else so I can figure out what I'm doing wrong?
The only thing I can think of is that the volume on the Virtual DJ VU meter is going from yellow to red. Could that be?
geposted Sun 04 May 25 @ 8:18 am
Sounds like an issue with the buffer for the ASIO drivers. Try increasing it to 512 in the Denon control panel.
geposted Sun 04 May 25 @ 12:03 pm
Maybe connected to a nearby blutooth device paired prebioualy with?
geposted Mon 05 May 25 @ 5:40 pm
My own experience on this kind of issue is: laptop failure (needs reboot + cooling)
geposted Sun 25 May 25 @ 2:58 pm
