Going through the guide for the MPD232 and into the XML mapper section there are entries for BANKC buttons 1 through 8, however they will not respond as the other banks of buttons (A,B) do.
It appears the action window will only respond upto and including MIDI CC 63, beyond this control change value there is no notification in the 'Activity' window. I can assign a button to a lower CC and it will work (for clarity, MIDI monitor [Mac app] records the transmission of midi activity on the higher CC values so the buttons undoubtedly operate.
Is there a mapping fix for this?
Incidentally all the rotary encoders, and dares work in control bank C, however their CC values are 63 and below.
Thanks
Thanks
geposted Sun 25 May 25 @ 1:30 pm
